1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | dantheman49-6400,
If you want to do it the right way...the permanent way, take the intake/exhaust combo off and have it machined at a automotive machine shop. The very least I would try is to loosen up the bolts holding the manifolds together at the heat box, reassemble the manifolds (with alignment rings),then after they were cinched down to the head, tighten the four bolts where they fasten together in the heat box.
Stuart | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I had the same problem. I ended up getting it all plained level. But before you go that route, make sure you loosen up all the bolts AND use the alignment rings to close off the intake ports. It was a pain in the butt to get it not to leak. Take your time and good luck! | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | It sounds like you do not have the alignment rings in the manifold. You really need these rings to seal it up correctly. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | And do not forget: If you have the intake/exhaust manifold planned flat to also have the alignment rings planned too! Otherwise the alighnment rings might be too long and prevent a tight seal.
I've been there and done that one too!!! | | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | alright cool! thanks a lot ! ill give it a try | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | to see if im in the ball park with good manifolds is to take a known good straight edge and place it across each manifold and check for full contact across all three flanges. then bolt the halves together at the heat box but loose enough to wiggle the manifolds and put the straight edge across all six flanges and see if contact is made. my manual says .10 max allowable misalinement of flat surface. ive been able to seal mine with positive results even without alignment rings but its much easier if you have them. ive also had to get them milled flat as a unit in order to get them to mate to the head. | | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | alrighttt well before i go and get them milled, im going to double up the intake gaskets and see what happens.hopefully i get some results. Thanks again! Danny
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | im going to double up the intake gaskets and see what happens.hopefully i get some results. you might solve your intake leak but then create an exhaust leak. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | [quote=dantheman49-6400]....i can tell its leaking by having the engine running and spraying some starter fluid right over the part where the block and manifold meet, ....
That could get exciting. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you are using the manifold from the original motor, the ports are smaller than the 261. Rings for the 261 will be too large. In the original photo it looked like the intake wasn't meeting the head. If an alignment wring hangs up, it will not seal. To seat it I lossen the bolts between the two manifolds and sfter it is mounted I tighten them again.
By the way I don't think there is such a procedure as "planing" the alignment rings. They are shorter than the combined depth of the two grooves. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Take it from somebody that torched a 1970 Barracuda with starting fluid, It could get exciting, of course there were other issues with the car that contributed but the flash is what started it.
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Acetyline or Propane is more convenient, and much safer than starting fluid for spotting vacuum leaks. Just unscrew the head from a Propane torch, leave the metering orfice imn place, and attach a 2-foot length of 1/4" vacuum hose. It's much easier to pinpoint leaks, and there's no dangerous accumulation of flammable liquid like using carb cleaner or ether creates. If your shop equipment happens to include an oxy-acetyline torch, running a low volume of acetyline from the torch tip is another clean, reliable vacuum leak spotter. Jerry
