5 members (ndkid275, 55shaker, Ridgeback, Woodcmiami, Gib70), 92 guests, and 1 robot.
Topics128,115
Posts1,056,626
Members48,450
Junior Member
Junior Member
Here is a link to my personal web space, not selling anything there, just showing you all what happens when your buddies tell you they are sick of seeing small blocks in all the hot rods.
http://www3.telus.net/CarTunes/home/Other%20stuff.htm
kind of a chronology of my trucks transformation, check back often as i update at least monthly. And yes that is a 4.6 northstar that is still mated to its original trans axle and the abs and traction control are still functional.
there is no replacement for displacement?
sure there is, its called a turbo!!
3B Offline
Hy rattle, I am in AWE not only are you a bolter, but a budding engineer, and a computer genius as well, I haven't figured out how to put pictures on here [if I knew how to take them] great great project thank you very much for sharing the pics with us, good luck with the rest of it
Intersting swap. Can't help but wonder if you now have rear steer however. cool
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I can only say WOW!!!
Hobert
"The Lord is my shepherd"
Z
Z Offline
did you think about putting the transaxle up front?then you could use a drop axle out back and keep your bed floor.
Junior Member
Junior Member
the unit currently does not have rear steer but very easily could, just put the rack in.
as for putting engine up front, i may just install a second unit up front and run with twin engines (depends how she performs with a single engine first)
Truely Amazing ! my brain is racked just looking at it.
1951 3100 Chevrolet
Anonymous
Unregistered
Anonymous
Unregistered
Nice work. I have been toying with the idea of putting a GM front drive system in a 59. The 3800 engine/transaxle would be my starting point. My welding helmet is doffed to you though. Looking forward to the finished product.
Wow!
I have a line on a Northstar and have been thinking about putting it in an old GMC. Now that I see its been done I have to find something else to do...
A twin engine 4 wheel drive...HMMmmmm...That'd be an awesome ride,for sure! I guess since you've gone this far with it,doing it again up front would be fairly easy,huh?
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Quote
Originally posted by rattle: as for putting engine up front, i may just install a second unit up front and run with twin engines [/QB]
I like how you think! smile
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
