0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | The dipstick in my 235 was broken when I got it and I haven't been able to find a replacement, new or used. I've got a longer dipstick that I can cut to the correct length but I don't know how long to make it. If someone could give me the dimension from the "full" mark to the point where it sits on the top of the tube I could make this one work. As always, any assistance is appreciated.
Jeff
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Jeff, I would just do a fresh oil change with the recommended amount of oil and run it for a few minutes to fill everything up then let it settle for 10 minutes, I do not have a 235 but would think it would be 5 qrt. Then just set your "NEW" unmarked stick in an use that level as your FULL mark. | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Hi,1)- From top of tube to engine is 7 1/4 inchs 2)- from stop washer to full mark on dipstick is 13 5/8 inchs 3)- overall dipstick from stop washer to end is 15 1/2 inchs
Pete | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Hi, 1)- From top of tube to engine is 7 1/4 inchs 2)- from stop washer to full mark on dipstick is 13 5/8 inchs 3)- overall dipstick from stop washer to end is 15 1/2 inchs
I would check it after You change the oil
Pete
| | | | | Joined: Jul 2005 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 153 | Now you've got me reciting the comercial "that's thinking with ya dipstick Jimmy" It will be stuck in my head all day!
mac | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Thanks for the info. I'll start with that and verify with my first oil change before marking the dipstick.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Jeff, I would just do a fresh oil change with the recommended amount of oil and run it for a few minutes to fill everything up then let it settle for 10 minutes, I do not have a 235 but would think it would be 5 qrt. Then just set your "NEW" unmarked stick in an use that level as your FULL mark. The 235 is 5 quarts without filter, 6 quarts with filter.
Bill Burmeister | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I HATE THAT COMMERCIAL!!!!!!!!!!!!1
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | I'm with you, WE b OLD! I'd like to teach that little weasel a lesson, and I'm thinking with MY tire iron! ;>) | | |
