| | | Forums66 Topics128,036 Posts1,055,460 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55380 01/21/2006 11:18 PM | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Purchased 53 3100,it been in restoration for 7 yrs and he gave up.now its my turn,engine rebilt about 6 yrs,I put new points,plugs,cond,cap,rotor vac advance,a rebilt Holley-Weber carb.Starts good run good on high RPM but Idles Rough.Took comp test,5 cyl at 125 lbs one at 120 lbs,any one have any Ideas? | | |
#55381 01/21/2006 11:37 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That is real good compression. You probably have a vacuum leak. Check around the manifold gaskets. Make shure the secondary throttle plate is closeing tight. Check point gap & for bent dist. shaft or worn bushings. Possible a valve clearance too tight. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#55382 01/21/2006 11:38 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Wow, all that on a 216, what a deal. Mr.G, your list doesn't say plug wires, but I'll bet you actually replaced them.
I would doubt the five pound difference would be detectable, and although I have never even seen one, the rebuilt carb would be my first suspect.
If you can verify no vacuum leaks anywhere, and the idle smooths out as the RPM's are brought up slightly, it would sound like a idle circuit problem in the carburetor.
I would make sure the wires are indeed new. You could let it idle rough for a couple of minutes, shut it off a take a peek at the plugs..you might find a surprise.
If it is smooth under a load, say lugging it up a hill, the ignition might be ruled out.
A "idle only" problem usually screams vacuum leak or idle circuit problems. Keep searching!
Stuart | | |
#55383 01/21/2006 11:55 PM | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Thanks,I have adj. valves 1st on a cold engine and @ and 3 time on a hot engine,new plug wires,new intake gaskets,???????? | | |
#55384 01/22/2006 1:29 AM | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Maybe the fellow you brought the truck from.Put a mild cam in it.check for vacuum leaks.cracked hoses to wipers,dist.Firing order.timming
dan-pa
#55385 01/22/2006 2:33 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mr. Giant,
Did you get the truck in this condition. Did you do all the work or did the previous owner. Have you ever heard the truck run perfectly...this problem has developed over time??
Stuart | | |
#55386 01/22/2006 2:59 AM | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | The engine was rebilt and put in the frame,cab installed,and never started,I purchased truck and this is the first it ran in 7 yrs.Now it is only cab and frame,Iwant to have it running good before I go on. | | |
#55387 01/22/2006 3:35 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mr. Giant, There are lots of good ideas in this thread. If you have done all the tune up stuff correctly and it sure sounds like you have, I think I would concentrate on the carburetor. I am not familiar with your carburetor, but it must have a idle circuit that is separate from the mid to high speed system. If it is ONLY a "at idle" problem, as soon as the carburetor is off the idle the engine should immediately smooth out. Don't forget to look at motor mounts as you indicate the engine is sort of just sitting there. If the engine isn't mounted properly it might tend to hop around and make you think it isn't running right. Sometimes you can use a aerosol can of Berryman or brake clean to find a vacuum leak. Remember to look at the plugs...they can give you good clues! Don't give up, it's only a 216. Stuart | | |
#55388 01/22/2006 3:37 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Had a similar problem and could not find it until I decided to change the steel vacuum line between the carb and the distributor. There was a small crack in the flared end of the steel line which I could not see until I took the fitting off. Give it a look, won't hurt. | | |
#55389 01/22/2006 4:32 AM | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | The Weber carb is a two Barrel w/ progresive linkage,I am going to see if the throttle plate on the second barrel is closed at idle,if it is I going to do the brake clean test,Stuart thank for the help along with everone else,What a great site THANKS I post what I find. | | |
#55390 01/22/2006 8:24 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | While you're looking for vacuum leaks,spray around the throttle shaft. The last 3 carbs I've had problems like this with,it was vacuum leaks around worn throttle shafts. Maybe I'm just gun-shy... Speed | | |
#55391 01/22/2006 5:04 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#55392 01/24/2006 2:10 AM | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | THANKS Guys,Found Leak on Intake manifold,Put new gasket on,now I have exhaust leak,Took it apart installed new gasket,intake Leak back,took it back apart,insall new gasket intake leak fixed,EXHAUST Leak BACK !. Time to walk away and try another day. | | |
#55393 01/25/2006 12:39 AM | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | sounds like the manifolds are warped or the head.check them with a metal square.You may have to get them planed down at a machine shop.Use proper torque pattern also
dan-pa
#55394 02/06/2006 3:26 AM | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Today i got back to my intake, had a friend hold intake and exst manifold , much easer wilt help.New gasket on no leaks 216 runs great,
Thank every-one for your help.
Don | | |
#55395 02/08/2006 11:17 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | glad you got it fixed and thanks for the feed-back..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
