5 members (Charles in CA, klhansen, FishinToms53, Hanks custodian, 5 Window 9434), 53 guests, and 0 robots.
Topics128,049
Posts1,055,634
#55329 01/20/2006 4:48 AM
Getting ready to put discs in the front of my '39. Where is the best place to find a turnkey package without having to scour the yards. Also what is the best rear to match the bolt pattern. (5 on 5?) I'm ready to go 15" if necessary but would like to keep stock hubcaps. I'm putting in a new 235 with a S10 T5 behind it. Whats everybody using?
#55330 01/20/2006 4:51 AM
Go get yourself a copy of Classic Trucks or Custom Classic Trucks and check out the vendors that advertise in them. I'll bet there's at least a half dozen that do just suspension and brake upgrades and conversions. Hope this helps some,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#55331 01/20/2006 6:23 AM
What he said.
#55332 01/24/2006 4:41 AM
Thanks Scott: I'm looking into it
#55333 01/25/2006 3:15 AM
i bought my front end adapters from ECI... they have a very informative catalog and a good website: www.ecihotrodbrakes.com
their adapter will allow me to use chevy rotors and calipers with my stock straight axle...
i'm building a '35 pickup w/350 tripower & 4speed and i'm using an s10/2wd rearend... my bolt circle will be standard 4 3/4" chevy so i can use about any wheels i want too and have the front match the rear... most likely chevy rally wheels as i'm striving for an all chevy theme as much as possible... plenty of chevy stuff available too...
sounds like you'll have a great truck...
bill w.
#55334 01/25/2006 11:58 AM
Gaffbro, I bought my disk kit from www.truckandcarshop.com (better price) but when I rec'd them all the paperwork was from www.classicperform.com (gofiger)and went with 5 lug 4 3/4. fit great on my '48! GOOD LUCK .
Hey Bill,(neighbor)don't mean to steer away from this thread but,when you put your V-8 into your '35 what r you gonna do about the steering box and column? Any plans?
bowtie
