2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 4 New Guy | | New Guy Joined: Jun 2009 Posts: 4 | Hello,
I am putting a 1953 Chevy 1/2 ton back together. It has a side mount spare, but I have new bedsides. Does anyone know where the mounting bracket goes? Pics without the tire and measurements would be great.
Art | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | Side spare mounts were usually either aftermarket or fabricated from the under bed carriers. Mount a tire on a wheel and see where it needs to go. Give yourself a little extra room in case you decide to use a larger tire later on. | | | | | Joined: Jun 2009 Posts: 4 New Guy | | New Guy Joined: Jun 2009 Posts: 4 | Thanks, They were a factory option on the half ton in '53 with an inset in the driver side fender. I wsa looking to see if anyone else had one that could take the measurement. | | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Welcome Outsideart, Go to the tech tip section at the top of the page. Under the body section, it should have what you need for spare tire side mount. Kevin  Kevin
| | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | Thanks for the tip. That guy put together a very nice document on making the bracket. | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Section 10, Sheet 3.00 of the 1947-1954 Chevrolet Assembly Manual shows detailed instructions with measurements on how and where it is mounted. Samantha | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The sheet in the Factory Assembly Manual might be useful but be careful. The bed side-panels/rails changed in 1954 (the drawings in the FAM are for a 55-1st truck).
There is a flat top in 54/55 but an angled top in 53. The mounting brackets for the spare carriers for 53 and 54 are necessarily different (to bolt to the differently angled tops of the different rails). Thus, the bolt holds may or may not be correct.
The measurements in the FAM might not be correct for a 53 bed. However, the bed-front to fender distance is the same, so you can most likely use that important measurement from the FAM.
| | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Art, I have a '53 with the original side mount carrier, here are some pictures...hope they help. http://rides.webshots.com/album/573391199BDXQJf
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Jun 2009 Posts: 4 New Guy | | New Guy Joined: Jun 2009 Posts: 4 | Thanks Magfarm51, Thats perfect. Art | | |
