1 members (pauld), 109 guests, and 2 robots.
Topics128,201
Posts1,057,281
Members48,467
Hello,
I am putting a 1953 Chevy 1/2 ton back together. It has a side mount spare, but I have new bedsides. Does anyone know where the mounting bracket goes? Pics without the tire and measurements would be great.
Art
Side spare mounts were usually either aftermarket or fabricated from the under bed carriers. Mount a tire on a wheel and see where it needs to go. Give yourself a little extra room in case you decide to use a larger tire later on.
They were a factory option on the half ton in '53 with an inset in the driver side fender. I wsa looking to see if anyone else had one that could take the measurement.
Welcome Outsideart,
Go to the tech tip section at the top of the page. Under the body section, it should have what you need for spare tire side mount.
Kevin wave
Thanks for the tip. That guy put together a very nice document on making the bracket.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
Section 10, Sheet 3.00 of the 1947-1954 Chevrolet Assembly Manual shows detailed instructions with measurements on how and where it is mounted.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
The sheet in the Factory Assembly Manual might be useful but be careful. The bed side-panels/rails changed in 1954 (the drawings in the FAM are for a 55-1st truck).
There is a flat top in 54/55 but an angled top in 53. The mounting brackets for the spare carriers for 53 and 54 are necessarily different (to bolt to the differently angled tops of the different rails). Thus, the bolt holds may or may not be correct.
The measurements in the FAM might not be correct for a 53 bed. However, the bed-front to fender distance is the same, so you can most likely use that important measurement from the FAM.
Art,
I have a '53 with the original side mount carrier, here are some pictures...hope they help.
http://rides.webshots.com/album/573391199BDXQJf
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
Thanks Magfarm51,
Thats perfect.
Art
