6 members (Hotrod Lincoln, Peggy M, Otto Skorzeny, DadsFirstPickup, dinosoar, Robert Crandall), 120 guests, and 2 robots.
Topics128,127
Posts1,056,675
Members48,450
#5525 04/23/2004 11:32 AM
I posted in HP but nobody seems to go there. Do any of you know of a newer 5 speed like would come in a half ton [no granny] that will bolt up to my 56 bell housing and not require any input shaft mods? The drive shaft is no problem as I am changing to a Dakota rear anyway.
Thanks .........................................Larry
A T-5 bolts up with a few easy to do modifications, check the past discussions here or check out the "Tech Tips" section on this site.If you got 1800 bucks handy, you can buy a brand new Richmond 5 speed that bolts up. If your truck is Chevy V-8, the NV 3500, first gear is 3.5,a little low, will bolt up ,but the intergal clutch housing may foul on the crossmember.
My 57 has a 71 350 truck engine. A T5 from a Camaro fits the bell housing perfectly. I put in a new clutch and pressure plate 'cuz I had it apart anyway, but you will find the new T5 has a different input spline than the older trans. In the Tech Tips section of this site, Grant Galbraith has a good piece on mating a T5 to an AD with an in-liner.
Thanks for the replys.
I'll check out the NV 3500 first as I want a light truck trans, I will be using the sub as a truck. The low first gear would be a good thing.
Thanks again................................Larry
Anonymous
Unregistered
Anonymous
Unregistered
The NV3500 will not bolt up to your stock bellhousing, it has an integral bellhousing that will fit engine if it is a V8.
If you have an inline 6 - I think your best shot for a 5 speed that will bolt up to your stock bellhousing is a T5
if you have v8 you could also use NV4500 wich is a evan better trany but reqiers a littel work to make it fit rite
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
