| | | Forums66 Topics128,148 Posts1,056,813 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#5525 04/23/2004 11:32 AM | Joined: Apr 2004 Posts: 36 Member | | Member Joined: Apr 2004 Posts: 36 | I posted in HP but nobody seems to go there. Do any of you know of a newer 5 speed like would come in a half ton [no granny] that will bolt up to my 56 bell housing and not require any input shaft mods? The drive shaft is no problem as I am changing to a Dakota rear anyway.
Thanks .........................................Larry | | |
#5526 04/23/2004 12:28 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | A T-5 bolts up with a few easy to do modifications, check the past discussions here or check out the "Tech Tips" section on this site.If you got 1800 bucks handy, you can buy a brand new Richmond 5 speed that bolts up. If your truck is Chevy V-8, the NV 3500, first gear is 3.5,a little low, will bolt up ,but the intergal clutch housing may foul on the crossmember. | | |
#5527 04/23/2004 10:19 PM | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | My 57 has a 71 350 truck engine. A T5 from a Camaro fits the bell housing perfectly. I put in a new clutch and pressure plate 'cuz I had it apart anyway, but you will find the new T5 has a different input spline than the older trans. In the Tech Tips section of this site, Grant Galbraith has a good piece on mating a T5 to an AD with an in-liner. | | |
#5528 04/24/2004 10:53 AM | Joined: Apr 2004 Posts: 36 Member | | Member Joined: Apr 2004 Posts: 36 | Thanks for the replys.
I'll check out the NV 3500 first as I want a light truck trans, I will be using the sub as a truck. The low first gear would be a good thing.
Thanks again................................Larry | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The NV3500 will not bolt up to your stock bellhousing, it has an integral bellhousing that will fit engine if it is a V8.
If you have an inline 6 - I think your best shot for a 5 speed that will bolt up to your stock bellhousing is a T5 | | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | if you have v8 you could also use NV4500 wich is a evan better trany but reqiers a littel work to make it fit rite | | |
