Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (1955 1 Series, 3B, Jay R, Wayne67vert, Phak1, DaveV, Hush), 123 guests, and 2 robots.
Topics128,274
Posts1,058,433
Members48,490
#552054 07/02/2009 8:12 PM
Can some one tell me if the HEI unit sold by Tom Langdon is a pointless dist. Also, what are the pro's and con's of using the HEI setup in a 6-cylinder, 235cu-inch 55 series 2 truck. Any info would be greatly appreciated. Oh, last question. When you set the points to .016-.019, aren't you also setting the dwell. In otherwords, there's no seperate setting for the dwell is there?
Pizza40
pizza40 #552059 07/02/2009 8:35 PM
we have a lot of recent topics about the dwell and the Hei..
please be so kind as to do a search.............
Redryder pix
My Hotrod
joker #552071 07/02/2009 8:53 PM
HEI ignitions all use an inductive pickup instead of points.
Point gap and dwell are two different ways of setting/measuring the same thing. Dwell is more accurate, but gap is easier without special equipment.
OldSub #552126 07/02/2009 11:39 PM
YES...Tom Langdon's is a inductive pick-up its and 80's model GM dist. Its a great unit and with the right round coil looks perfect. Tom is a great guy to deal with and his products stand the test of time....get one and say goodbye to points you will not be sorry! SJB
I'm running Tom's mini HEI and it's one of the best additions to my truck. Now she starts first crank and burns the gas, no more sooty plugs. Also any parts you need are at any parts store, not so with 50 years old points etc.
I have a very inexpensive and old Dwell Meter, best way to check points setting.
1946 1/2-Ton Chevy
Tom's mini HEI was the best thing I did to my 235 ... been running it for 10 years now and 30,000+ miles without a hitch ... starts first time every time, better mileage, no foolin' with points and constant tune-ups.
