| | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | Hey Fellas, Does any of the major brands (Mallory or MSD) make an electronic distributor/ignition setup for my 1957 Chevy 6 cyl 235cui??? If so, recommendations and/or suggestions?? THANKS J.R. in VA
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Search the manufacturer's sites for that info. Stovebolt Engine Co does offer an electronic dizzy and there is always Pertronix. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | You can use any point type distributor to trigger an MSD or you can convert your existing distributor to full electronic with a Pertronix kit for about 80 bucks and 15 minutes. What many like is to use the later 250/292 GM HEI distributor which is all self contained and takes one wire to hook it up. It has to have the shoulder on the housing moved up about 3/8" to get full oil pump meshing but that's it. They make a collar to clamp it down and every parts store in the world has parts on hand for it.
Evan
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Mallory has one in their Uni-Lite line. I'm running one in mine. If you run it with the recommended best performance Promaster coil, you will need a HyFire box. I'm running a 3RLi box with mine, as it has a rev limiter in it. I'm also running Pro Sidewinder wires. Parts are redily availabe at any Mallory dealer.
Bill Burmeister | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
