1 members (Hotrod Lincoln), 73 guests, and 1 robot.
Topics128,055
Posts1,055,782
Hey Fellas,
Does any of the major brands (Mallory or MSD) make an electronic distributor/ignition setup for my 1957 Chevy 6 cyl 235cui???
If so, recommendations and/or suggestions?? THANKS
J.R. in VA
Search the manufacturer's sites for that info. Stovebolt Engine Co does offer an electronic dizzy and there is always Pertronix.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
You can use any point type distributor to trigger an MSD or you can convert your existing distributor to full electronic with a Pertronix kit for about 80 bucks and 15 minutes. What many like is to use the later 250/292 GM HEI distributor which is all self contained and takes one wire to hook it up. It has to have the shoulder on the housing moved up about 3/8" to get full oil pump meshing but that's it. They make a collar to clamp it down and every parts store in the world has parts on hand for it.
Evan
Mallory has one in their Uni-Lite line. I'm running one in mine. If you run it with the recommended best performance Promaster coil, you will need a HyFire box. I'm running a 3RLi box with mine, as it has a rev limiter in it. I'm also running Pro Sidewinder wires. Parts are redily availabe at any Mallory dealer.
Bill Burmeister
Drew
