2 members (lumbersawyer, klhansen), 75 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#552392 07/03/2009 8:21 PM
is there a preferred order to install the exhaust and intake manifolds ? looking to buy pass the school of hard knocks
eliminatethis #552409 07/03/2009 9:35 PM
I know I know your all laughing at me. It looks simple 1st on is the exhaust then gasket then intake right! but all the time I see threads on somebody has to replace the old ones because after they had installed them they leak and sometimes ruined there 1st set. So that's what I am asking if they are that delicate it there better way to install for best sealing and least risk of damage
eliminatethis #552419 07/03/2009 10:01 PM
Stock manifolds or aftermarket (Offy/Fenton) ?
There will be some differences in how they install. In any case, the gasket and port rings go first, then exhaust, then intake. If you are using the stock manifolds, you'll want to bolt them together at the heat riser first, then install. Replacing the bolts with studs helps as well, as they help hold the gasket in place. See the pic at the bottom of this page for proper tightening sequence and torque specs.
Bill Burmeister
LONGBOX55 #552421 07/03/2009 10:05 PM
stock, thanks
eliminatethis #552436 07/03/2009 11:33 PM
What engine are you referring to?
If it is a 216/235/261 in a standard cab truck, did you take your stock manifold assembly apart? If so, after you assembled the two pieces you might want to have have the port side planed/ground/surfaced.
tclederman #552478 07/04/2009 2:08 AM
Ive never had mine apart, but I seem to recall some posts regarding issues with alignment. I was thinking it might be best to bolt the intake and exhaust together loosly, then install, tightening up everything a little at a time. Any thoughts on that?
My 1953 Chevrolet
1947.1 Gallery
rustednuts #552503 07/04/2009 3:27 AM
I think you are right Rusted nuts.
I do know that the procedures are outlined in the shop manual.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
rustednuts #552799 07/05/2009 2:43 PM
it is a 235 and Rustynuts I believe you right THANKS
eliminatethis #552829 07/05/2009 4:44 PM
I will second that. The two manifolds should be bolted together loosely and tightened after mounting. I use two of the interior bolt positions to hold the gasket in place. After some of the other bolts are started, I remove them and mount the real hardware. The thing to look for is to make sure the locating rings don't get hung up. They should not provide any resistance when mounting the manifold.
1951 1 Ton Completed
