4 members (JW51, ronsway, Guitplayer, Hotrod Lincoln), 157 guests, and 2 robots.
Topics128,109
Posts1,056,271
Members48,439
#552328 07/03/2009 2:58 PM
I have a buddy who is looking for a "shift lever assembly" but is not sure just what transmission he has.
The casting numbers are: side: GM465452
On the top: GM18, and below that is: 3901131
I would appreciate any help in identifying this transmission or finding out where I can get this information. He called Chevrolet and they played brain dead. Thanks for any help. williejoebob
what year truck is it?
3 speed or 4?
column lever assembly or top loader lever?
probably a muncie like this one on ebay http://cgi.ebay.com/ebaymotors/CHEV...imsxq20090606?IMSfp=TL090606132003r34572
I found it by googling gm465452. I don't quite understand what part you are looking for.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
boy, we all jumped on this one at the same time. I was posting just to bring it back up so we could help.
1953 Chevrolet 3600
I'll do my best to get as much information as I can. Thanks for the interest.
Okay, here's what I know now: 4 speed with floor shift. He needs the shift lever and the "top cover" of the transmission that the shift lever goes in (and the connecting ball and pins from lever to top of the transmission). Apparently, someone just stole the shift lever by breaking it off. I hope i'm making sense.
Trans came out of an 87 chev 1 ton dually, but not sure original to that truck.
casting numbers: went to Ebay---465462 same on both; his--3901131 vs. Ebay 3901127.
plate on side has: 59000 E 67044;(not sure if maybe added by shop that rebuilt trans earlier);
His also has F217 on top below 3901131.
Working on photos. Is the pan the top of the trans? Thanks again.
I'd just take some measurements of the cover bolt arrangement and start walkin the wrecking yards, likely any 80's top loader will have the identical top and lever regardless of minor model changes
pan ID's are bottom of automatics, don't apply here
It should be an SM465. Common from late 60's to early 90's.
Steve
'49 3800
'52 3600
'57 3100
Thanks to all.
Williejoebob
