7 members (greenie-reddy, klhansen, carbking, Mike B, Hotrod Lincoln, cmayna, Woodcmiami),
60
Mod | | | Forums66 Topics128,030 Posts1,055,421 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55176 01/18/2006 4:14 AM | Joined: Oct 2005 Posts: 28 Member | | Member Joined: Oct 2005 Posts: 28 | I'm new to the 64 -66 chevy trucks. Would a 72 250 with powerglide (from a 72 pontiac ventura) bolt right in to one of these trucks? The 250 has side engine mounts on it. If so what kind of gas mileage should I expect? I'm not very familiar with the powerglide transmission. | | |
#55177 01/18/2006 4:32 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | This would be a good question for lilred66 , i'm sure he will chime in on this question. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#55178 01/18/2006 4:47 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If it's a Chevy engine it should be almost a direct bolt in with maybe a few minor exceptions. Scott | | |
#55179 01/19/2006 12:16 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What size engine is in it now? If it is a 230-250 six cyl. it will bolt right in. The gas mileage depends on what rear end ratio it has. It will be somewhere in the area of 15 mpg. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#55180 01/19/2006 1:56 AM | Joined: Oct 2005 Posts: 28 Member | | Member Joined: Oct 2005 Posts: 28 | Wrenchbender, I have a 62 now that I am going to sell for parts (no engine). I am in the market for a solid 64-66 shortbed to restore so I can't answer your question. I posed the question because I may be able to put my hands on a strong running 250 with powerglide out of a 72 ventura. 15 mpg does not sound like much for a six cylinder. I want to put a 283, 292, or 250 in the truck with an automatic transmission but I also want something that will give me decent gas mileage. What engine and rearend gears would you recomend? I do have someone that has offered me what he says is a good running 283 with a powerglide for $500. I believe he said the engine and trans came out a 67 or 68 malibu. I appreciate your response! | | |
#55181 01/19/2006 11:16 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I think I would get a truck first & then see what you need in the way of engine. The 63-66 are great trucks. Almost any engine -trans fit them. It is also easy to change rear end ratio,s. The ratio you want to use depends on engine size & tire size. Also you need to consider what you are going to haul or pull. I had a 63 with 454 & o-drive auto. trans. Neat truck.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#55182 01/20/2006 2:04 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | the powerglide won't give you good mileage.id try to find a 305 and turbo 700r4. | | |
#55183 01/20/2006 1:54 PM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | The '72 250 motor does not have the tabs on the front of the motor to fit up to a truck/car that uses the front mounts like a '55 Chevy. I believe '69 to '72 were all without front mounts. Before you jump, check out your intented truck to see where the mounts are. I didn't and now have a '72 boat anchor in my garage.
