4 members (farmallb, Gib70, Gdads51, Nick in Manitou), 132 guests, and 3 robots.
Topics128,088
Posts1,055,998
Members48,430
#551033 06/30/2009 12:00 AM
Hello,
I was wondering if anyone has refinished the wood in their bed with out removing it. Mine just needs to be freshened up a bit, the woods still fine but needs to be refinished. I just wanted to lightly sand it and polyurethane it. I don't really want to remove it if I don't have to, but I don't want to scratch up the stainless steel pieces either.
Joe
54 Triumph TR2(rhd)needs total resto.
60 Apache 10 stepside shortbed
99 Excelsior Henderson
Its been done in the bed, but my opinion is to really do it right, it should be removed so you can reach all sides to make sure its sealed properly. I guess if only the top needs a touch-up, you could pull the stainless and lightly sand and re-coat. Others may think differently.
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Joe, I'd consider something more than just urethane. The folks at Mar-K did a test on different finishings a while back that I think you will find interesting without me going into a history story here. A search will probably give you more reading than you want. I also think Mar-K has the test still going on. Its very interesting and may help you make a decision.
joe,
i had the same dilema. my unprotected wood was getting mildew on it.
so, not wanting to remove all those darn bolts either, i did mine while still in the truck.
first i pressure cleaned the wood, let it set for more than a week, then masked the strips, sanded the wood, then stained then clear coated.
details are in my picture descriptions.
http://s251.photobucket.com/albums/...00/?action=view&current=DSC01735.jpg
http://s251.photobucket.com/albums/...00/?action=view&current=DSC01734.jpg
http://s251.photobucket.com/albums/...00/?action=view&current=DSC01744.jpg
http://s251.photobucket.com/albums/...00/?action=view&current=DSC01743.jpg
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Thanks for the replies, I really appreciate it. You guys have some really beautiful trucks. I will do some searching first before proceeding. Leonard my slats are getting some mildew too toward the front of the bed where water pools unti it drains. I think I will try your idea, I really don't want to unbolt the floor either.
Joe
joe,
the way i did it was actually pretty easy.
like i said, after i pressure cleaned all the mildew off, i waited a week for it to dry.
took a sanding block and sanded the wood, taped it up, stained it one day, the the following day i started applying 2 coats per day, one in the morning and one in the late afternoon.
you cant tell by my pics, but i should have sanded the wood a little more, since i have a slightly rough finish, and i really need to sand it maybe one more time, then add another few coats of clear. but it was a lot easier than removing all the strips and wood, and really came out pretty good.
have fun, and let us know which route you go, and post some pics...
leonard
....just be sure to get some on the ends guys are the ends will start turning black on you...
