| | | Forums66 Topics128,010 Posts1,055,298 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 42 | What thermostat should a 1955 235 have. My temp will almost peg and then drop back on the dash gauge. Normal running will put the gauge about 3/4 Could the gauge be reading high. | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | 180 degrees is typical. Mine runs at the mid-point of the gage. Make sure it is facing the correct way. You can check it in a pan of water, with a cooking thermometer for verification. Put it on the stove and measure the temp when it opens. You might also consider your sending unit and/or gage ground. It is possible the thermostat is working properly, but your readout isn't accurate. I'd do a cal-check to isolate the issue. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=513363Bill | | |
