4 members (1955 1 Series, Steelonsteel, ShopRag, Gdads51), 78 guests, and 0 robots.
Topics128,210
Posts1,057,459
Members48,471
I have an older 235 that has a breather tube with a cap.
When the engine is running, there is no puffing or air discharge from the bottom of the vent tube. I think thats good.
When the engine is running you can see oil leaking from beneath the cap. The oil drips down the outside of the vent tube and marks the floor. The oil escaping is constant.
Maybe the cap gasket needs fixing?
Has anyone ever had this problem?
sound's like a little bit of blow bye the ring's ,try to clean the breather cap out it may help delay the drips and change the gasket to make it fit tighter ,any coming out the road draft tube ?
Nothing is coming out of the road draft tube...in fact I feel no air movement from it when the engine is running.
Maybe it is blocked & some pressure is escaping from the cap?
I have seen mud dauber wasp plug that tube solid which caused the same leak ether way remove tube and make sure it is clean
Yes, it sounds like the road-draft tube is blocked/clogged. It is fairly easy to knock the tube out of the block and check to see if it is clogged (it is press-fitted into the block).
You can soak the tube in kerosene in an attempt to unclog it (some people have reported that they burn-out a clogged road-draft tube - I have never done that).
I've used a wallpaper steamer to steam them clean. When they plug they really plug and you should probably cycle some solvent or diesel through it before using the steamer.
How good is the gasket on the cap?
My Blog
Is the oil baffle in place?
