1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 18 Apprentice | | Apprentice Joined: Oct 2006 Posts: 18 | I have a 38 chevy pickup 1/2 ton with the 216 engine, I have looked for a 235 for about a year and all I find is junk. Now I have run into a 250 with 4 barrel and mild cam, My question will this swap as easy as the 235 and bolt to everything or am I looking at a project. I have looked for info but I am coming up with nothing, would like to keep it simple but this engine is interesting.
Thanks Jack | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jack M, the short answer is no. You'll have to make engine mounts, and adapt to your transmission, if you intend to keep that, give us some more info on what you want to do, hope that helps. | | | | | Joined: Oct 2006 Posts: 18 Apprentice | | Apprentice Joined: Oct 2006 Posts: 18 | Thanks Shop Shark, Wanted to keep it simple so it's back to the hunt. Jack | | | | | Joined: Oct 2006 Posts: 18 Apprentice | | Apprentice Joined: Oct 2006 Posts: 18 | One more question, What engines will swap simply besides a 235?
Jack | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | actually chassis engineering makes some simple to use engine and trans mounts i have a 39 i have used these on and teh up side is i am going with a 250 inline but the chassis mounts are the exact same as a sbc so at a later date if i wish to go v8 i can  but the motor mounts run me 24 and the universal chassis ones ran me 40 far as the trans mount i used the stock crossmember that was already in the truck i will try to snap a few pics today and post them on my photo if interested
1937 1/2 ton
| | | | | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | Well, any time you change engines there is always something you run into that you haven't figured on. I put a 396 in a 350 hole and it wasn't bad, but it did require some changes, mostly in the area of the cooling system.
I would look for a good 235. There have to be some out there. If you can't find one, the 250 probably wouldn't be that difficult. I know you would have to fabricate engine mounts, get a new bellhousing and somehow get your radiator hooked up to the engine. Also, I don't know if you could use the original generator on your engine or have to adapt the vehicle over to an alternator. If so, that would be considerably more time and probably money, depending on how much stuff you have on hand. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Look in the Gallery at Joe Hand's beautiful 37 running a 250, very nice job. | | | | | Joined: Oct 2006 Posts: 18 Apprentice | | Apprentice Joined: Oct 2006 Posts: 18 | actually chassis engineering makes some simple to use engine and trans mounts i have a 39 i have used these on and teh up side is i am going with a 250 inline but the chassis mounts are the exact same as a sbc so at a later date if i wish to go v8 i can  but the motor mounts run me 24 and the universal chassis ones ran me 40 far as the trans mount i used the stock crossmember that was already in the truck i will try to snap a few pics today and post them on my photo if interested Daniel, Could you post a few pic's. Thanks Jack | | | | | Joined: Oct 2006 Posts: 18 Apprentice | | Apprentice Joined: Oct 2006 Posts: 18 | Look in the Gallery at Joe Hand's beautiful 37 running a 250, very nice job. Nice, Looks like a snug fit but nice. Jack | | | | | Joined: Oct 2006 Posts: 18 Apprentice | | Apprentice Joined: Oct 2006 Posts: 18 | Thanks for all the replys, gives me something to think about.
Jack | | | | | Joined: Jan 2008 Posts: 21 Apprentice | | Apprentice Joined: Jan 2008 Posts: 21 | Shame your so far away jack I have a 235 just sitting in the garage that i could only hope to trade for a 216 i want to rebuild mine but when I bought my truck the engine was a puzzle in the bed of the truck I've had the block cleaned and tested but haven't found a couple of parts that might be beyond repair. Plus its hard to put something back together that I didnt dissasemble or have even gotten to reaaly look at up close and personal
