8 members (tclederman, Hotrod Lincoln, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom, Otto Skorzeny),
179
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55005 01/14/2006 6:24 PM | Joined: Apr 2001 Posts: 162 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 162 | I have seen trailer mounting brackets for leaf springs sold at the farm and home store. Why wouldn't they work for mounting leaf springs? Are they not load rated enough?
My dumb question for the day.
Tim
53 3100 1929 Ford Roadster Pickup 1934 Ford Pickup 68 Plymouth Satellite RR Clone 2 Door My Fleet
#55006 01/15/2006 7:48 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Um...mounting leaf springs on what? Can you give us a bit more info? | | |
#55007 01/15/2006 9:32 PM | Joined: Apr 2001 Posts: 162 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 162 | Conceptually what would be the difference between what Chassis Enginnering or street rod companies sell and what you can buy for making trailers?
Is it that the trailer mounts are for flat stock?
I have a 46 Ford that will need parrelel leaf springs and I don't want to pay $131.00 for the brackets they sell if I can get them for $40.00 at the local store.
Also I want to trade out the closed driveline on my 53 chevrolet truck for a rearend from a 77 chevy truck. Do you just weld the mounts on the axle to meet where the original axle goes?
#55008 01/16/2006 1:07 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Are you talking about the spring perches that weld to the axle tubes? If so, I haven't ever found any at the tractor supply stores that are as wide as the automotive leaf springs, just the narrow little trailer springs. If you are needing the torque plate that the U-bolts go through, all you need are the plates that are as wide as your springs and U-bolts and are made with a heavy enough guage steel. Hope this is what you are needing, Scott | | |
