6 members (tesa, 55shaker, Shade Baby, Gray_Ghost, LAROKE, Wally / Montana), 120 guests, and 2 robots.
Topics128,076
Posts1,055,922
Members48,430
#550019 06/26/2009 2:36 PM
I've tried searching for this info but 1000 items pop up. I have a 216 (1947) that I'm putting in my 1950 Panel for now. What plugs does it take? I've been to Ac M8, is that correct?Engine is bone stock along with everything else. Thanks, Brian
briank #550039 06/26/2009 3:51 PM
AC M-8 or AC 108 are correct. These are the small 10MM plugs.
briank #550042 06/26/2009 3:55 PM
The M8 AC plug should be correct and may be hard to find now days. Champions I have are UY-6 may be easier to locate.
1946 1/2-Ton Chevy
Be careful when you tighten 10mm plugs. The shell can break if you treat them as you would a 14mm plug. I don't know the torque specification for those; in the past, everyone (almost everyone) knew the correct 'feel' for seating them- or they soon discovered it.
Harvester
Harvester #550086 06/26/2009 7:42 PM
Thanks everybody for the info.FYI don't go to Autozone for plugs, they rely too much on the computer. I went to the local parts place and pulled out the trusty Ac book and got my plugs. Thanks again.
