| | | Forums66 Topics128,076 Posts1,056,008 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 27 Apprentice | | Apprentice Joined: Apr 2008 Posts: 27 | My carburetor bowl has striped threads at one of the 4 bolt holes. I was wondering if I could repair it using some of the alumiweld alloy material and retapping. Any suggestions? Thanks! | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | not familiar with that product but have used devcon with some success ,also is there enough meat lift to go with a larger thread or different pitch screw that will catch ? using a tap to re thread . | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | A heli-coil would probably be the best bet, you should be able to retain the original bolt. A kit would have the proper drill and tap for the application. I've used these before with great success. Not difficult at all and is permanent. Good luck
Ed
| | | | | Joined: Feb 2000 Posts: 5,213 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,213 | I second the Heli-coil. The kit cost a bit, but you can save the carb with little work and its all hand work since the taps are so small. Joe | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | I also agree - go with the Heli-coil. That's the best way to take care of it. Samantha | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I also agree, try the Heli-coil if you have enough material around the original hole
Grigg | | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | Heli coil is the way to go.... Had a 4 cyl F*&d few years back to put an engine in at work... New head had 7 or 8 helicoils never came back no water leaks or nonething ...kid dirving it was about 19 at the time. Just FOLLOW instructions to the letter.
Brad | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I agree too! What are we talking about here? | | | | | Joined: Feb 2000 Posts: 5,213 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,213 | We all agreed the next one to agree will send us all a $50 in the mail! Thanks, I will be waiting by the mail box. Joe | | | | | Joined: Apr 2008 Posts: 27 Apprentice | | Apprentice Joined: Apr 2008 Posts: 27 | I am glad there was so much consensus on the solution to my problem. Here is how it played out for me. The screws were a size #10 with a 28 pitch thread. when I went to the to my local ACE Hardware store to find a helicoil, I could only find a #10/24 or the next size up was a #10/32. Even when stepping down to a #8/24 I thought there was just not enough material surrounding the hole to make it work. So I did a retapping using a #12/24. The tap cut just enough of the surrounding material to give me good threads. I am sorry if I disappointed every one but that is how I worked it out. By the way, I gave it one good pull on the choke and the truck runs great. I have made no further adjustments to the carb after rebuiding it. One other thing I used pine sol to soak my carb in over night. I am very pleased at how well it cleaned it up. My wife loved the fresh pine scent in my garage. Thanks to every one. I am on to the brakes now, need to change the brake fluid. | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Tulsa, I'm glad that worked for you! I don't think anyone is dissapointed that you didn't go with the Heli-coils! What's important is that you were able to fix it properly so it can get back on the road soon!  Samantha | | | | | Joined: Feb 2000 Posts: 5,213 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,213 | Never heard of Pine-sol for cleaning! I might try that since everything else stinks so bad. Glad it worked out. Joe | | |
