5 members (NJC, Bill Hanlon, baldeagle, Peggy M, carbking), 62 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#547815 06/18/2009 5:55 PM
guys, take a look at the picture on this link. i have a truck, with no wiper arm, but the vacuum pump works and the shaft moves when the engine runs. let me know if i need a new assembly, or if i need the arm only. thanks
http://img40.imageshack.us/img40/6648/0617092239.jpg
Gocart879 #547825 06/18/2009 6:36 PM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Looks like the end of the shaft is broke off where the wiper arm attaches to...Joe
#548677 06/22/2009 2:15 AM
ok, so what should i do, do i need a new wiper motor? or can this be repaired. im looking to see if anyone has a picture of a intact wiper assembly so i can see for myself how much damage there is so anyone with one let me know. thanks
mike
Gocart879 #548737 06/22/2009 4:12 AM
yes you need a new wiper motor ohwell the damage is you're missing a half inch of the end of the main shaft that's the 'heart' of the motor and the part the wiper arm needs to attach to - not a repairable sorta thing .... picture
Flxible #548817 06/22/2009 3:17 PM
OK thankyou for your input. i appreciate it. it just seems odd to me how the end of the shaft on the truck is tapered and doesnt seem to have any broken parts off of it. but i will do further research into this and see what i can figure out. thanks again
Gocart879 #548820 06/22/2009 3:37 PM
probably the 1st thing to do is get a correct wiper arm, then you can see how it fits, or not .... should be a flat ended shaft out beyond the bezel nut that holds the wiper on, either has a hole for a pin/set screw, or knurling like a more modern setup .... what year truck?
Flxible #548870 06/22/2009 7:46 PM
the truck is a 1942. its a fire engine. its still got the vacuum motor in it , and it works well thats why im so dissapointed. i have just started tinkering with this at our fire station so i dont know any prior history on it or why the arm is gone.
Gocart879 #665987 07/29/2010 1:24 AM
Hello, I figured I would just revive this older thread because it has all the info already as well as pics.
I have the same end on my wiper motor as the 2 pictured in this thread. The second picture looks exactly like my wiper motor.
As Gocart897 stated:
"it just seems odd to me how the end of the shaft on the truck is tapered and doesnt seem to have any broken parts off of it."
Mine appears the same-not broken. If it is not broken, how would a wiper arm attach and turn the wiper arm? Friction?
The end looks like brass. I can see that there is knurling holding this small piece on the shaft, it could be removed easily.
Would this be the correct wiper arm. Part #WW122... http://www.oldchevytrucks.biz/34_46/full.asp?page=138
Anyone have firsthand experience with this wiper?
Wiper is out of my 46 half ton.
Thanks, Aaron.
lowbow #665997 07/29/2010 2:03 AM
I can't vouch for that wiper directly but I will say that the ones I ordered from Jim for my 53 was right and good quality.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
FriedGreenTmater #666134 07/29/2010 3:32 PM
I figured it out. It is broken. red58 is correct (sorry for doubtin ya)
It is just not obvious when you have it in hand because where it is broken has a clean break and the area is VERY thin. Horrible design.
FriedGreenTmater, I'm just going to go with Jim's 6 volt motor set up. He hasn't let me down yet.
Thanks.
Moderated by  ndkid275, Phak1
