Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (2-Ton, Peggy M, Youngin' Tut 59, Jon G), 36 guests, and 7 robots.
Topics128,010
Posts1,055,303
Members48,419
#548000 06/19/2009 3:57 PM
I found a '61 Apache Stepside shortbed but really want a fleetside. The guy that has it also has a '64 Chevy Fleetside shortbed and he thinks the beds could easily be switched out and work correctly. Does anybody know if this would be an easy switch and would it look correct.
THanks,
Huthip
huthip #548014 06/19/2009 5:05 PM
According to several of the bed supplier sites, the wood and bolting strips are the same for 60-66. The bed strip bolt kits fit 58-72, and the bed to frame bolts fit 55-72. The frames are different from 60-62 and 63-66. The earlier version is much stronger like a convertible and has torsion bar front suspension. The later frame is a typical ladder style with a conventional coil spring front suspension. For availability of aftermarket parts the 63-66 frame is more desirable, since almost nobody makes anything for the 60-62 chassis, although a later 67-82 front suspension swap is relatively easy.
Regarding the bed swap it should be an easy swap. The only question might be whether the bed mounting bolts line up in the same exact place between the two frame styles. Good luck.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Markeb #548015 06/19/2009 5:07 PM
Thanks for the information.
huthip #555655 07/14/2009 10:22 PM
If you were closer. I could sell you a fleetside bed on a 3/4 frame with a rear and 6 bolt wheels
