| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 56 | I found a '61 Apache Stepside shortbed but really want a fleetside. The guy that has it also has a '64 Chevy Fleetside shortbed and he thinks the beds could easily be switched out and work correctly. Does anybody know if this would be an easy switch and would it look correct.
THanks,
Huthip | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | According to several of the bed supplier sites, the wood and bolting strips are the same for 60-66. The bed strip bolt kits fit 58-72, and the bed to frame bolts fit 55-72. The frames are different from 60-62 and 63-66. The earlier version is much stronger like a convertible and has torsion bar front suspension. The later frame is a typical ladder style with a conventional coil spring front suspension. For availability of aftermarket parts the 63-66 frame is more desirable, since almost nobody makes anything for the 60-62 chassis, although a later 67-82 front suspension swap is relatively easy.
Regarding the bed swap it should be an easy swap. The only question might be whether the bed mounting bolts line up in the same exact place between the two frame styles. Good luck.
| | | | | Joined: Feb 2009 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 56 | Thanks for the information. | | | | | Joined: Jul 2009 Posts: 1 New Guy | | New Guy Joined: Jul 2009 Posts: 1 | If you were closer. I could sell you a fleetside bed on a 3/4 frame with a rear and 6 bolt wheels | | |
