0 members (), 151 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
#547180 06/16/2009 3:55 PM
Apprentice
Apprentice
have you guys seen this, where they use the power steeing pump to run the brake booster, it says that its alot more braking for the buck, just wanting some thoughts, since I havent got even closeto that point(just trying to think ahead)
lol i posted a whole thing bout that same thing bout a month ago and got alot of respose so i take it alot of ppl like it
1937 1/2 ton
Got a link to this part?
i was told best hydrovac to use was from the chevy astro i went to our local pull-a-part salvage and the whole setup only runs 20.00
1937 1/2 ton
I think that you have the terms hydraboost and hydrovac mixed up.
I have been running a GM hydraboost in my 64 for 19 years now works good. I did have a detroit diesel and you can't draw vacuum from them so this is the alternate solution. they were available from all Gm trucks(light duty) that ran diesels( whenevr they came out) from about 75 onwards.Mine was out of a 75 4 x 4 suburban
ron
Apprentice
Apprentice
didnt work
what is with the page. what do you want us to see
ron
Apprentice
Apprentice
well this one was a ebay item, 250443437955
power brake booster/hydroboost system for chevy truck, couldnt make the link work
that is quite similiar to the one that I have in mine though the mounting looks a little different. mine is an earlier one and it mounts in the same as the old single m/c mounts( I can't see the mounting in the picture
ron
