8 members (KEVINSKI, mick53, 55shaker, Peggy M, Gdads51, Hanks custodian, MickeyP, 1 invisible),
148
Mod | | | Forums66 Topics128,089 Posts1,056,137 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 45 Apprentice | | Apprentice Joined: May 2009 Posts: 45 | have you guys seen this, where they use the power steeing pump to run the brake booster, it says that its alot more braking for the buck, just wanting some thoughts, since I havent got even closeto that point(just trying to think ahead) | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | lol i posted a whole thing bout that same thing bout a month ago and got alot of respose so i take it alot of ppl like it
1937 1/2 ton
| | | | | Joined: May 2005 Posts: 57 'Bolter | | 'Bolter Joined: May 2005 Posts: 57 | | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | i was told best hydrovac to use was from the chevy astro i went to our local pull-a-part salvage and the whole setup only runs 20.00
1937 1/2 ton
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I think that you have the terms hydraboost and hydrovac mixed up. I have been running a GM hydraboost in my 64 for 19 years now works good. I did have a detroit diesel and you can't draw vacuum from them so this is the alternate solution. they were available from all Gm trucks(light duty) that ran diesels( whenevr they came out) from about 75 onwards.Mine was out of a 75 4 x 4 suburban ron | | | | | Joined: May 2009 Posts: 45 Apprentice | | Apprentice Joined: May 2009 Posts: 45 | didnt work
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | what is with the page. what do you want us to see ron | | | | | Joined: May 2009 Posts: 45 Apprentice | | Apprentice Joined: May 2009 Posts: 45 | well this one was a ebay item, 250443437955 power brake booster/hydroboost system for chevy truck, couldnt make the link work
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | that is quite similiar to the one that I have in mine though the mounting looks a little different. mine is an earlier one and it mounts in the same as the old single m/c mounts( I can't see the mounting in the picture ron | | |
