5 members (55shaker, Rich'sToys, 59 fleet, pdlightning, 1 invisible), 140 guests, and 5 robots.
Topics128,077
Posts1,056,032
Members48,433
#546803 06/15/2009 4:04 AM
Is the fan spacer needed for proper cooling? I've put a 62 235 in my 59 project truck and the radiator won't fit with the fan spacer on. Trying to avoid buying the short shaft water pump kit, but if I gotta I gotta
phnman23 #546849 06/15/2009 7:50 AM
heres what I have been told ..the optimal distance for the fan to radiator clearance is 3/4".
That said, why not machine down your 2" spacer to achieve the required clearance?...may be an aption in your situation if 2" is too much?, on my 52 I took a 1/4" off on a mill to get my distance set at 3/4" and I have never had any overheat issues.
just my 2 pennies.
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #546934 06/15/2009 7:13 PM
Tim has it right...I chucked my aluminum spacer in the lathe cut it down and got my new flex fan 3/4" from the radiator. 3/4" is as close as you need to be. If your motor mounts are sloppy the engine can dip forward and run the fan into the radiator if you are too close. Too far away and the cooling values drop....good luck, Steve
WHO, ME ? #546949 06/15/2009 8:23 PM
The radiator on my 1950 1/2 ton had been moved about 3 inches away from the motor, I think when someone replaced the 216 with the current 235. When I pointed it out to someone, it was suggested I buy a spaced to get the fan closer to the raidator. After buying the spacer and a new fan, I realized I could move the radiator back to its original position and achieve the 3/4" to 1" spacing. I had been having cooling troubles, so hope this helps.
Lawrence
prime 50 #546957 06/15/2009 8:46 PM
There shouldn't be a spacer on a '55-'59 truck.
Bill Burmeister
