4 members (TUTS 59, Southerntruck, WICruiser, Napco Man), 171 guests, and 3 robots.
Topics128,162
Posts1,056,941
Members48,458
Anyone know the whereabouts of instructions on how the door rubber is intalled? This is the rubber that runs around the perimeter. I've run across tese instructions for 25 years when I didn't need it. Today I'm mocking up the doors and can't find the instructions.
Any help would be welcomed.
Keith
take it outta the bag and plug it in the holes wink
it's useful to use some adhesive [like 3M] around the dog leg and under the bottom edge - and that metal strip is really needed under the bottom, as well as the small clips at the bends/corners .... the 'lip' goes toward the opening
Mine is one length. ..not a loop...where does it start?
Tx Red
Keith
with the split ones it works to have the joint in the middle of the bottom where the metal retainer can hold it snug
The one piece rubber has a single right angle. That goes in the lower corner at the back of the door.
FWIW, I used both Steele and Soffseal door rubber and couldn't get my doors to shut. I ended up needing two thicknesses of rubber so the doors would align correctly. See:
http://picasaweb.google.com/ChrisAurit/ItSChrisGreenTruck#5349524038267861362 and http://picasaweb.google.com/ChrisAurit/ItSChrisGreenTruck#5349521497789796018 for the end result of the experiment.
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
I had same problem and shaved down the door seal to make it work. I have shaved doors with 80 lb pulls but they would not open the door as the seal from lmc with plastic tips was to tight a fit. Where did you get the two types you used to work?
