1 members (CuzzFuzz), 83 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#54577 01/05/2006 9:23 PM
I have a 54 235 motor in my truck now, SHOT. I keep looking for a good V8 or a good I6 to replace it with. Recently I was looking at a later model 63 230 in great shape.
I know I would probably need to fab some motor mounts if the 230 mounts are on the sides. The 230 motor does not come with an intake manifold and possibly no exhaust. Does anyone know if my 54 235 intake and exhaust manifolds would work on the later model 230. If mine won't work are the 230 intakes readily available and are they reasonably priced?
I have a SM420 4 speed on the floor, any problems there?
What else would I need to be aware of for this change out?
Thanks for your help.
If you didn’t skin a knuckle while you were working on your truck, you weren’t working hard enough!
53 5window 1/2 ton
54 3window 1/2 ton
#54578 01/05/2006 9:47 PM
The 230 is a shorter and narrower engine. Nothing interchanges with the 235. Intakes and exhaust are available, the 230 and 250 are interchangeable. The exhaust manifold on the 230/250 has a poorer quality casting than the 235, tends to crack easier, so inspect carefully. Last trip I made to a local junkyard they had a 250 with manifolds still on it. The HEI from any GM six (75 & on) is a drop-in. The SM420 will bolt to the bell housing from either engine, but there is a difference in clutch linkage with the newer housing. Tom Langdon at www.stoveboltengineco.com sells a motor mount kit that makes the swap easy.
Fred
52 3600
69 C-10
#54579 01/05/2006 10:15 PM
Thanks, that information is very useful and that link was great.
Thank you,
Dan
53 5window 1/2 ton
54 3window 1/2 ton
#54580 01/05/2006 11:08 PM
And Clifford Performance sells all sorts of speed parts for the L22s.
1954 GMC De Luxe COE
#54581 01/06/2006 5:10 PM
What is the power like in a 230, compared with a 135 hp, 217 lb-ft 235? Anyone know?
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
#54582 01/06/2006 5:59 PM
Apprentice
Apprentice
Someone please answer Hot Rod Dad's question...because I will be doing the same.
1951 Chev.P.U. Streetrod-project
1951 Chev cpe 261 5-speed-50%
1953 Chev cpe 350/700-95%
1962 Chev Bubbletop 409 -75%
#54583 01/06/2006 7:19 PM
#54584 01/06/2006 9:53 PM
Now, that is a darn useful link, ChucktheTruck!
