| | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54577 01/05/2006 9:23 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | I have a 54 235 motor in my truck now, SHOT. I keep looking for a good V8 or a good I6 to replace it with. Recently I was looking at a later model 63 230 in great shape. I know I would probably need to fab some motor mounts if the 230 mounts are on the sides. The 230 motor does not come with an intake manifold and possibly no exhaust. Does anyone know if my 54 235 intake and exhaust manifolds would work on the later model 230. If mine won't work are the 230 intakes readily available and are they reasonably priced?
I have a SM420 4 speed on the floor, any problems there?
What else would I need to be aware of for this change out?
Thanks for your help.
If you didn’t skin a knuckle while you were working on your truck, you weren’t working hard enough! 53 5window 1/2 ton54 3window 1/2 ton
#54578 01/05/2006 9:47 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The 230 is a shorter and narrower engine. Nothing interchanges with the 235. Intakes and exhaust are available, the 230 and 250 are interchangeable. The exhaust manifold on the 230/250 has a poorer quality casting than the 235, tends to crack easier, so inspect carefully. Last trip I made to a local junkyard they had a 250 with manifolds still on it. The HEI from any GM six (75 & on) is a drop-in. The SM420 will bolt to the bell housing from either engine, but there is a difference in clutch linkage with the newer housing. Tom Langdon at www.stoveboltengineco.com sells a motor mount kit that makes the swap easy.
Fred 52 3600 69 C-10
#54579 01/05/2006 10:15 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | Thanks, that information is very useful and that link was great.
Thank you, Dan
#54580 01/05/2006 11:08 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | And Clifford Performance sells all sorts of speed parts for the L22s. | | |
#54581 01/06/2006 5:10 PM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | What is the power like in a 230, compared with a 135 hp, 217 lb-ft 235? Anyone know?
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
#54582 01/06/2006 5:59 PM | Joined: Nov 2005 Posts: 39 Apprentice | | Apprentice Joined: Nov 2005 Posts: 39 | Someone please answer Hot Rod Dad's question...because I will be doing the same.
1951 Chev.P.U. Streetrod-project 1951 Chev cpe 261 5-speed-50% 1953 Chev cpe 350/700-95% 1962 Chev Bubbletop 409 -75%
#54583 01/06/2006 7:19 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | |
#54584 01/06/2006 9:53 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Now, that is a darn useful link, ChucktheTruck! | | |
