2 members (VicZ, doyle1950), 143 guests, and 1 robot.
Topics128,087
Posts1,055,974
Members48,430
working on a 54 4100 dump. i was wondering what regulations i would have to follow if i was to change the dump bed. allthough not practical, i was thinking about buildig a functional dump bed from oak (i own a portable sawmill so lumber is not an issue.)
regulations? who regulates rebuilding truck beds and how would they know? why is oak not practical? sounds fine for a 54, think grain truck wink
most old big trucks were sold as chassis + cab only, and the purchaser took care of whatever type body they wanted out back
PENDOT? i was thinking there may be minimal strength requirements regarding the floor, sides, gate, ect. a bit of engineering is required to do it right as wood is a bit different than steel. i may be overthinking this but being cmv driver i deal with alot of regs.
plan on using it for licensed commercial hauling? a 4100 is only a 1.5T, maybe 10,000GVW, can't imagine you'll be hauling loads of rock from the quarry grin
it's much more common to find a 50's truck with a wood deck and sides, steel's too heavy and there'd be few jobs that'd need it - the stake deck that the factory made was all wood with a metal band around the edge of the deck and some metal corner hardware - do what you know will do the job it's for .... good 2" stock makes a pretty bulletproof deck for these ol rigs
There are no regs on the building of a body except as to lighting, width, etc. None on the design or fabrication that I'm aware of after 43 years in the truck body/equipment industry. There are regs on the installation. OSHA has regs regarding safety concerns on dumps, i.e., the cab shield. It must cover the driver so it is different on each model of truck cab.
As to the rebuilding of one you are home free. Contact me if I can be of help to you.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Just remember pound for pound wood is stronger than steel.
I have seen trucks with white oak beds that out lasted the truck.
Welcome to the Bolt.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
Thanks for all of the responses.
i dont plan on using it for commercial hauling, and the gvw on this truck is 1400lbs, it has an option with extra springs on the front.
Dave, i jut may contact you in the future, after the white oak and walnut is out of the kiln. install regs?, i am guessing these must pertain to the pivot point and related issues regarding a dump bed.
thanks again
Tom
