| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54495 01/05/2006 2:30 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I recently "acquired" a 350 engine that I know to run good as I had heard it run on many occasions. It is a rebuilt engine with a tag on the side which says Aaron's Automotive Prod. Springfield,Mo. The usual engine # was ground off or shaved off if the block was decked. Does anyone know of this company? A phone #? A web search didn't turn up anything. The casting # on the back of block is GM460776 so what can any of you tell me about this engine or the rebuilder. The engine was most likely built about 3 years ago. The tag didn't say if the engine was bored or anything. It is suppose to have only about 15000 actual miles on it. Any help appreciated gang. Oh, Aarons Automotive "serial #" is engraved on the tay and is 167209. | | |
#54496 01/05/2006 6:54 AM | Joined: Nov 2001 Posts: 16 Junior Member | | Junior Member Joined: Nov 2001 Posts: 16 | The engine block casting number indicates a 1976-1979 305 cid, 2 bolt main. Without the engine ID number, normally located on the pad just forward of the passenger side cylinder head, it may be difficult to get more specific. What vehicle was the engine taken out of? About the rebuild, have you called Aaron's Automotive? Their phone number is (417) 831-5257. They may have some info for that serial number. | | |
#54497 01/05/2006 9:56 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can run casting numbers and date codes at www.mortec.com and www.nastyz28.com
Fred 52 3600 69 C-10
#54498 01/05/2006 10:42 PM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | thanks guys. the engine appears to be a 78-79 from the web site of Mortec.com. I also called the phone # and they are no longer known as Aarons Automotive but now called Performance Power Train. I had their(Aarons) serial # but they could tell me nothing. Thanks for all the help. Now I must decide whether to use it or not. It was wrapped up when I got it and the fellow said it was a 350. I had heard it run in his truck and had no reason to not believe THIS guy. I guess he honestly didn't know himself. It was running and sounding good. Any way, I got a good deal on it so I'm not "hurting" over it!! I may still put it in the Panel and hit the road. Thanks again for your help. | | |
#54499 01/05/2006 11:20 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I had bad experience with Aarons years ago. It almost put me out of business. It is probably better now as reman. engines have improved in quality & warrantys. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
