Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (homer52), 118 guests, and 6 robots.
Topics128,281
Posts1,058,469
Members48,490
#543112 06/03/2009 2:47 AM
hello, just picked up a 33 1.5 ton chevy truck and was wondering are the rear wheel bearings packed in grease and accessible by removeing the bolts and flange or are they lubbed by gear lube in differential? I have a feeling theyre greased but dont want to disassemble if there is no reason. if any one can help, thanks alot!
There is an exploded view in the parts book and it only shows an inner seal which leads one to believe the rear wheel bearings ran in gear lube. Some rears had two seals, an inner and an outer and they require bearings to be packed in grease, but it doesn't appear that is the case. If the wheel turns smooth, I would leave well enough alone.
I think Chevy used only gear oil, while some GMCs used both.
It certainly wouldnt hurt to pull the axles/hubs and check out the condition of the bearings. You might catch something now, that will save you a costly repair in the future.
Plus after sitting for a length of time youll probably want to replace the grease seals before watching the gear oil run out onto the brakes. Just a thought.
Jeff
My 1953 Chevrolet
1947.1 Gallery
1 Offline
I can't say for a 33 but my 47 is gear lubed from the differential. To check just pull the cover off the center of the hub that hides the axle. If it's gear lubed moving the axle slightly out should start to make a mess (oil will start running out. Trust me I should know after having the hubs off 5 times...
1947farmer
1947 2-Ton Chevy
Story in the Stovebolt Gallery
More pix in Photobucket
1977 3/4-ton
1985 2.5-ton
2- 1947 Allis WC
1- 1949 Allis allcrop
1- 1955 Allis WD-45
1- 1976 Allis 7040
"If it ain't broke you ain't trying"
Big Bolt Forum Co-moderator
I would take it apart.. but I just love taking things apart. It's so much faster than putting it back together. Seriously, if the truck has sat for any amount of time I would redo them.
1948 Chevy 2-Ton
Thanks so much for all the responses! I would like to add that upon loosening the brake linkages and s cams etc I came across as a greenhorn, a grease cup around back of the backing plate directing toward where the wheel bearings would be, so this answers part of my question. However There is after allowing to set a day a little gear lube smelling fluid seeping from the seal on the drivers side. As one of you guys said some GM,s used lube and grease. I would like to had thought I could leave it alone but with this leak guess I need to do something to avoid future problems as you guys mentioned. Might be inner and outer seals, I'll have to get a break down for this rear end and get some seals and gaskets etc. And yes this truck sat almost sixty years in a barn, but has low milage so not a lot of wear to the mechanical parts i have been into thus far. Engine sounds good, Lights and guages work. Hope to have on road sometime in july. Very exciteing becomeing a stovebolter. Still open to suggestions on these 1933 1 1/2 ton rear wheel bearings. Thanks, Ken
