4 members (Hotrod Lincoln, Otto Skorzeny, Bill Hanlon, 1 invisible), 70 guests, and 1 robot.
Topics128,090
Posts1,056,026
Members48,432
#54366 01/03/2006 2:55 AM
Does anyone know a source for various SM420 manual transmission parts. I already purchased a rebuild kit, but I need other parts that are not included in the kit like:
- Universal Joint Flange assembly
- Speedometer gear
- Special washer(s) to hold U-Joint front flange
- Counter Shaft rear bearing oil deflector
- 2-7/16" Counter shaft cover
Any help locating these parts will be appreciated. Thanks
Jim
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#54367 01/03/2006 3:24 AM
Ask in the swapmeet, there's many of them out there,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#54368 01/03/2006 7:55 AM
Jim
As Scott said or try http://www.novak-adapt.com
#54369 01/03/2006 1:44 PM
Steve, I purchased my rebuild kit from Novak, but I did not see that they gthey had any other SM420 parts available. Do you believe that theu do have other parts available?
I was looking here to see if there where any vendor sources for these parts, but if there is not, then I will head over to the swapmeet section and ask. Thanks.
#54370 01/03/2006 3:22 PM
Novak is aimed at guys w/ jeeps, but it don't hurt to ask, they might have some leads for ya
