| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | How is the best way to remove the steering arm. What tool is required? Will a late model puller work or is it something special? Pulling column prior to cab comimg off frame. While Im at it what about rusted brake & clutch pedals..... Thanks Brad | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | You can buy a cheap pitman arm puller at places like Harbor Freight Tools for about $10.00 or so, or rent one at your local FLAPS. To remove the arm, put the puller jaws behind the arm after loosening the nut on the arm and screw the large bolt on the puller into the sector shaft coming out of the steering box. Do not remove the bolt - just loosen it so the arm doesn't come flying off in your face. Be careful!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Joe has it right the HF puller works like a champ for 10$ If you tighten it and it doesen't pop tap it on the side away from the machined surface. Also tighten it and walk away for a few minutes and then tighten it a little bit more works most of the time. For anything rusted PB Blaster or similar spray and let it sit overnight then come back to it. You didn't say where the pedals are stuck? Is it the large assembly off the frame or the fine thread bolts that hold them together right behind the firewall? | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you may even borrow one from some ''flaps''
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | Brake pedals have never been off either cab, so any help would be appreciated. I know the pivot on orginal master would not come off a year or so ago, rebuilt master on trk. Last license plate on donor trk is 1988. Thanks Brad | | |
