4 members (Otto Skorzeny, Johnny Rib, dwreills, 1 invisible), 95 guests, and 3 robots.
Topics128,036
Posts1,055,461
Members48,422
#542670 06/01/2009 3:29 PM
1 Offline
Is it just me or is anybody elses 2WD trucks rear diff only 1WD?
3 Speed Or No Speed
1965 Chevrolet C10 Stepside
Most are open diffs,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 Offline
Could you explain that to me, i don't know much about it.
3 Speed Or No Speed
most diffs are open meaning all the power is transferred to 1 wheel,the one with the least resistance,ie one wheel on the gravel,one on pavement,the gravel wheel will spin.Good for driving in wet or in town where there is lots of corners,etc.Hence the one wheel peel!A positraction puts power to both the wheels at all times and a locker will lock up both wheels when one spins.
65 Chev shorty
65 Chev longbox
65 Chev crewcab
65 Chev bus!
Photobucket pictures
timbuk #542793 06/02/2009 1:00 AM
a posi does not put power to both wheels all the time- hence the term limited slip. there are clutches involved which will lock up when requiren
now if you welded up the spider gears you wood have a locked rear endand both wheels drive constantly and evenly, which would make it harder to go around corners.
a locker allows you to lock them up by you when required
ron
padresag #542887 06/02/2009 6:12 AM
when my posi rears aint spinnin both tires,it means there blown! eek
65 Chev shorty
65 Chev longbox
65 Chev crewcab
65 Chev bus!
timbuk #542944 06/02/2009 3:20 PM
"A positraction puts power to both the wheels at all times "
that is what you stated
no
ron
padresag #543023 06/02/2009 9:59 PM
1 Offline
Ok now now enough fighting gentlemen, i appreciate yalls help in providing information. Now, would it be expensive or complicated for me to get positraction or whatever that makes both wheels spin on my truck?
3 Speed Or No Speed
1965 Chevy C10 #543051 06/02/2009 11:44 PM
there are various type of rear axle setups and he is referring to positraction which is a limited slip rear axle w/clutches in it. it is not a constant 2 wheel drive rear axle.it will engage in certain criteria( all he understands that if he stands on it in a straight line both tires will smoke.that is one of the criteria). you would not want to drive around with both wheels driving constantly as it is a pain turning with it.
you could check under the parts for sale here as someone may have a used one that you could rebuild and install (oiginal equip). you should ask a few of them that are in the bus. of selling parts.
you may be able to still by a new unit.
you should be able to buy a detroit locker for it and there are other makes out there
ron
padresag #543068 06/03/2009 12:38 AM
1 Offline
thanks for the help ron
3 Speed Or No Speed
Hey 65,
Check into Mosier or Currie for a bullet proof rear diff. They are beefed up Ford 9" rears custom made to fit your needs. I put one in my brother in-laws 55 Shoebox and it has held up very well,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks #543180 06/03/2009 6:12 AM
what is the cost factor on one of these custom units. more than likely built for 950hp to?
ron
padresag #543228 06/03/2009 3:58 PM
Cost depends on how it's built, mild to wild. The one I installed was built for a 383 stroker with 3:55 gears for about $1200.00. It was complete with covers, paint, brakes and drums,
Scott
Scott Ward
1 1950 3100
1 1963 K20 (454)
1 1964 C10 (350)
1 Offline
Well not that expensive i guess. Now, the day i realised my truck does the 1 wheel peel i tried to see what my rear end gear ratio was. Do both wheels have to be off the ground and the truck has to be in gear or something? Cause i tried it in neutral with one off the ground and came up with 1.25:1 or something which can't be right since the smallest in '65 was a 3.07:1. Any tips?
3 Speed Or No Speed
hey there pull the rear diff cover off and divide the small number off the crown gear into the big one.Ill pretty much be guessing they are 373 ratio,seems to be the most common ratio for these years.
65 Chev shorty
65 Chev longbox
65 Chev crewcab
65 Chev bus!
timbuk #544339 06/07/2009 1:24 PM
Instead of turning once turn 10 times.
LG
I don't own a vehicle that isn't old enough to drink.
LGriffin #544422 06/07/2009 8:51 PM
This would be the easiest way to get a locker type rear. no swapping of the carrier, just swap out the spider gears. Much less setup, and the cost is lower. Plus, it is a true locking diff, not a limited slip.
Bill Burmeister
