Just a tip,
Take a 1/8" drill bit an drill between the mountin bolts on the door skin and trough the hing, we will get back to that in a second.
Take the door(s) off, get your sawhorses and a pc of plywood roughly the size of the door an a scrap pc. of carpet an lay the door down on it.
Now with the door laying flat and GRAVITY not messin with ya an makin this job 10 times harder than it should be ..finanglin the glass an vent windows isnt NEAR THE CHORE IT CAN BE WITH THE DOORS ON THE TRUCK.
After you get the new glass installed slide your doors back over your hinges and use the same drill bit ya used to drill the holes as a locater to get your doors back to exactly (well darn near) where they was before removin em.
It makes this job SO MUCH EASIER!
How I did mine and would do again if & when needed.
I spent lots of intimate time with my doors fitting the cadillac regulators in there for the power windows IT DOESNT HAVE TO BE CHORE.
Tim
