1 members (stlcardinalsguy), 71 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#542253 05/30/2009 10:07 PM
Hi guys, here is what I have. 1951 Chevrolet 3604 with original 216 engine and 4-speed transmission. I have had the truck for 3 years now and never had a transmission problem until last fall when I notice backing it out of the garage. I would begin to release the clutch and it would lurch backwards a little bit and seize up. Now, if you put it in reverse and then into second and release the clutch it sometimes will go. When everything is cold (not been started or run in a day), she takes right off, but after a couple of minutes (warming up driving), when you come to a stop, I can't take off again, the trans. freezes up again. So I put it in reverse, then second, then reverse again, and then pray it will take off, and it usually does after a little "twanggggg" from the tranny. My fluid level is full, I was afraid I had run it dry and it was seizing up. Is is the syncro's? That's my only other guess. You can feel the tranny "shutter" so I don't think it's the clutch. But I don't know, so that's why I'm asking. Thanks for your time guys! Jeff
Wada #542277 05/31/2009 12:49 AM
Jeff,
Does your 3604 truck have a totally enclosed driveline? My first thought would not be the tranny but rather a u-joint that was near failure. For the transmission to act this way I think you would have evidence of a terribly sloppy shifter and some type of gear clanging or bearing whine.
I wouldn't rule out a ring and pinion problem either. If the transmission has a band style parking brake, give that a inspection too. I think the tranny guts would be my last choice though.
Stuart
Maybe some brake hardware broke and is wedging in whenever you change directions,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Thanks for you information and suggestions guys. I really don't know much about transmissions. I do have an old school mechanic that I will have inspect. I will forward your suggestions to him as well. Thanks, Jeff.
