| | | Forums66 Topics128,180 Posts1,057,157 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 6 New Guy | | New Guy Joined: Apr 2009 Posts: 6 | Hey everyone, i picked up a 1962 fleetside long bed recently and love it. A friend of a friend gave me a 89 suburban with a bad motor and i was wondering if the front end will fit into my 62. Thanks for any info. Justin | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | You can make anything fit if you have fabrication and welding skills. Forgive me for asking, since I am not familiar with the '62 trucks, but doesn't your '62 already have an independent front suspension with upper and lower control arms, springs and shocks? If so, what are you planning to do with your stock set up? I'd like to upgrade my '52 3/4 ton to an IFS but I don't want to use car suspension parts; it's a truck and I want to use truck parts. | | | | | Joined: Apr 2009 Posts: 6 New Guy | | New Guy Joined: Apr 2009 Posts: 6 | It does have IFS but i want the disc brakes. Unless there is a disk brake conversion to the original front end that i don't know about. Is there? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The '62 has torsion bar IFS. I've heard that people have swapped to the '63 to '87 IFS on those trucks, but I don't have any details.
Is the '89 Suburban still the same body style as an '87? If so the IFS is the same design as the '63 to '87 pickups.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2009 Posts: 6 New Guy | | New Guy Joined: Apr 2009 Posts: 6 | Thanks oldsub. I actually have a front end from a mid 70's truck but the suburban one is in better shape. It is the same body style as the 87 so hopefully it will fit in mine. Guess i'll find out this summer. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | As long as the front suspension unbolts from the frame it's an earlier model. The later ones had it integrated into the frame, which would require grafting, no good, Scott | | |
