1 members (SlimSix), 129 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
#540304 05/23/2009 6:52 PM
can any one tell me if the pump and drive unit {from the tranny} a intalled KIT
the unit on the tranny is a chelsea dana corp so would the pump be made by the same outfit
i need seals for the pump but have no idea where to look for them any help would be wonderful
thanks perry
http://s427.photobucket.com/albums/.../?action=view&current=numbers005.jpg
1963 Chevy C60 Apache Dump Truck
Stovebolt Gallery Page
Photobucket pictures
3B Offline
Hy Perry Dean, I'm away on vacation at the moment, is the pump mounted right on the p.t.o. or is there a small driveshaft to it? Also look for any ID. tags on the pump, or we could find seals by size if you disassemble. I will be back to my books June 1st, hope that helps.
thanks bobb
no hurry im starting a summer run so il be in n out all summer long {i hope}
i have took it apart there rubber comprestion bushings seals.
there was no tag i could find anywhere.
here are some pics of the pump all sides and numbers i could find
body casting number is 17650-1
i guess its the date 4 63
ser# 11145?? as best i can tell
http://s427.photobucket.com/albums/pp359/oldwestrnwear/hydralic%20pump/
The PTO and pump are made by two different manufacturers. Give these guys a call. They carry seals and may can identify your pump. http://www.baumhydraulics.com/home.php?xid=d1dc56d40b329e429646f250f34dbcb9
thanks crenwelge
i shot them a email and they probly have the seals.
i need to mesure the safts and get back with them
one other thing
is there any way to tell who made the pump there is no tag
its attached to the frame behind the cab with a small drive shaft from the chelsea dana corp PTO
Moderated
Moderated
perry dean you find seals for your pump i need some for mine and cant seem to find them anywhere.
Looks like an old Perfection pump made in Galion OH and has been out of business for many years. These are low pressure gear pumps meaning 1000-1200 PSI and were about 12 GPM@1000 RPM. It would help if you supply a photo of the hoist it operates if that is what your truck has. Perfection farm hoists were twin telescopic cylinder types and used an O ring seal. Not terribly good cylinders either I might add but the pumps were OK and equal to the other national brands. They (as did the competitors) also supplied pumps to other builders of truck mounted equipment so it wouldn't necessarily have to be a Perfection hoist. I sold a ton of them when I was a dealer for them and had little trouble with the pumps.
As for seals just find a seal specialty house on the internet and measure the shaft size for the packing ID and the stack height. It probably has about 5 pieces. There are MUCH better seals available now than the originals. Should NOT be a problem to get seals for it or much of anything else. If you pull the front & rear covers of it to check the wear plates you'll need to replace the thin paper gaskets with the exact same thickness or the pump will loose pressure and not work well. Worn bronze faced wear plates will allow slippage past the side of the gears. If yours still pumps well then leave it alone and just deal with the leakage.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
