2 members (TUTS 59, Leo),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | can any one tell me if the pump and drive unit {from the tranny} a intalled KIT the unit on the tranny is a chelsea dana corp so would the pump be made by the same outfit i need seals for the pump but have no idea where to look for them any help would be wonderful thanks perry http://s427.photobucket.com/albums/.../?action=view¤t=numbers005.jpg | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Perry Dean, I'm away on vacation at the moment, is the pump mounted right on the p.t.o. or is there a small driveshaft to it? Also look for any ID. tags on the pump, or we could find seals by size if you disassemble. I will be back to my books June 1st, hope that helps. | | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | thanks bobb no hurry im starting a summer run so il be in n out all summer long {i hope} i have took it apart there rubber comprestion bushings seals. there was no tag i could find anywhere. here are some pics of the pump all sides and numbers i could find body casting number is 17650-1 i guess its the date 4 63 ser# 11145?? as best i can tell http://s427.photobucket.com/albums/pp359/oldwestrnwear/hydralic%20pump/ | | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | thanks crenwelge i shot them a email and they probly have the seals. i need to mesure the safts and get back with them one other thing is there any way to tell who made the pump there is no tag its attached to the frame behind the cab with a small drive shaft from the chelsea dana corp PTO
| | | | | Joined: Mar 2014 Posts: 1 Moderated | | Moderated Joined: Mar 2014 Posts: 1 | perry dean you find seals for your pump i need some for mine and cant seem to find them anywhere. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Looks like an old Perfection pump made in Galion OH and has been out of business for many years. These are low pressure gear pumps meaning 1000-1200 PSI and were about 12 GPM@1000 RPM. It would help if you supply a photo of the hoist it operates if that is what your truck has. Perfection farm hoists were twin telescopic cylinder types and used an O ring seal. Not terribly good cylinders either I might add but the pumps were OK and equal to the other national brands. They (as did the competitors) also supplied pumps to other builders of truck mounted equipment so it wouldn't necessarily have to be a Perfection hoist. I sold a ton of them when I was a dealer for them and had little trouble with the pumps.
As for seals just find a seal specialty house on the internet and measure the shaft size for the packing ID and the stack height. It probably has about 5 pieces. There are MUCH better seals available now than the originals. Should NOT be a problem to get seals for it or much of anything else. If you pull the front & rear covers of it to check the wear plates you'll need to replace the thin paper gaskets with the exact same thickness or the pump will loose pressure and not work well. Worn bronze faced wear plates will allow slippage past the side of the gears. If yours still pumps well then leave it alone and just deal with the leakage.
