| | | Forums66 Topics128,050 Posts1,055,754 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 67 | This might need to be in the tech section but What years were hydraulic cylinders used? I have a 62 with one and having a lot of trouble. Has anyone try to change on over to a linkage type or should i keep working on the cylinders? Thanks
1947 1Ton stepside 1962 K20 Fleetside 1962 C40 12' flatbed 1963 C10 Stepside 1963 C20 Fleetside 1965 C10 Stepside (Daily Driver) 1973 C20 Stepside fire truck 1973 C50 Utility truck Houston Power & Light
| | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | my 61 gmc 4x4 k1000 had one ,but i had a don-er 65 3/4 2 wd and i swapped it to the manual clutch linkage and single master cylinder . | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | Years they were used is 1960-62 , in 1963 they went to a single. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | there is not much that can cause a problem. repairing or replacing either the master or slave cyl is a lot less work and expense than changing the linkage over ron | | | | | Joined: Aug 2007 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 67 | thats waht i thought but was not sure the more i look at it it may be a clutch problem the slave is moving about 2 in but there is no way to get it in grea with out craming it and grinding no mater how long you wait but onec in great it doesnot just take off you have to release the pedal thanks for the help guys
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | check the fluid level.it may need bleeding and or it may need adj; about 3/4" free play at the top of the pedal. the other possibility is that the clutch is worn out. ron | | | | | Joined: Aug 2007 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 67 | fluid good 3/4 good after looking at it a gain it proly is clutch thanks for all the ideas well i wanted t o put a detroit in it neway so i will just do it sooner than later thanks again
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I just took out a 453 and went back to a small block after having it in my truck for 18 years ron | | | | | Joined: Aug 2007 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 67 | padresag how hard was it to mount the 453 what size truck did you put it in? Thanks
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | it was in a 1/2t 4 x 4 panel-1964. you must be talking about the C40 are you. does a C40 have a straight axle under it ron | | | | | Joined: Aug 2007 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 67 | Yes for some resson 1962 was the only year Chevrolet put the torsion bar sup. under the c 30 and c 40 in 1963 they went back to a straight axle the dry weight of a 453 is not much more than a 283 so i thought that the front end could hold it
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | you better do a little more research on those 2 engs weights. when I removved the 453 and 5 speed the frame went up 2 3/4" and when the 283 w/t5 went in it only went back down a 1/4" bare 453 weighs in at 1150lbs, 283at what 565 lbs and everything else that attaches to either varies quite substantialy ron | | | | | Joined: Aug 2007 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 67 | wow sounds like it may be i do need to find a straight axle
