BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
2 members (Flatlander, VEW),
541
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: May 2009 Posts: 14 New Guy | New Guy Joined: May 2009 Posts: 14 | will a 1bbl off a 302 ind.GMC fit my stock 235? | | | | Joined: Jan 2008 Posts: 4,903 'Bolter | 'Bolter Joined: Jan 2008 Posts: 4,903 | Are you asking will it fit or will it work? Most 302's had a 2 bbl. A 1BBL would probably be a Zenith. They are very application specific. A 235 will not create near the velocity as a 302 and would result in a terrible flat spot during acceleration. Air rushing through the venturi is what sucks the gas out of your fuel bowl. With decreased velocity your mixture would be way too lean. | | | | Joined: May 2009 Posts: 14 New Guy | New Guy Joined: May 2009 Posts: 14 | thanks for the info.i am new to this "older iron" | | |
