2 members (Phak1, jmoore),
154
Mod | | | Forums66 Topics128,282 Posts1,058,493 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 14 New Guy | | New Guy Joined: May 2009 Posts: 14 | will a 1bbl off a 302 ind.GMC fit my stock 235? | | | | | Joined: Jan 2008 Posts: 4,988 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,988 | Are you asking will it fit or will it work? Most 302's had a 2 bbl. A 1BBL would probably be a Zenith. They are very application specific. A 235 will not create near the velocity as a 302 and would result in a terrible flat spot during acceleration. Air rushing through the venturi is what sucks the gas out of your fuel bowl. With decreased velocity your mixture would be way too lean. | | | | | Joined: May 2009 Posts: 14 New Guy | | New Guy Joined: May 2009 Posts: 14 | thanks for the info.i am new to this "older iron" | | |
