0 members (),
100
Mod | | | Forums66 Topics128,261 Posts1,058,346 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 32 Apprentice | | Apprentice Joined: Mar 2008 Posts: 32 | I decided to rebuild my 1955 235 cu engine that I have in my 53 Chev 1/2 ton. I purchased a cam and lifters combo, I wanted to go with the mechanical cam and lifters.Whats in it right now is hydraulic cam and lifters. Cam went in fine lifters AOK, but when I went to place in pushrods and rockers assembly it became obvious that the pushrods were to long. I looked up on Jim Carters site and saw that they sold shorter pushrods , they still seems a bit long. Has anyone else done this or came across this problem which can give some advice specifically somebody that has placed in a mechanical cam and lifters in a 235! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Sealed Power Part # RP3020 w/ Hydraulic Cam Size - 11.474" O.A.L. Sealed Power Part # RP3018 w/ Mechanical Cam Size - 10.819" O.A.L.
Try your Local Parts Supplier
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Mar 2008 Posts: 32 Apprentice | | Apprentice Joined: Mar 2008 Posts: 32 | Thanks’ OilRag I thought that maybe somebody else might have had the same problem but the info you gave me it probably exactly what I need , like I said I think I need them a little bit smaller and from 10 9/16 to 10 7/16 is about the size difference I need . Thanks for the help...
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | There is a 10 7/16" push rod listed for the 216 engine Part house #3019 Length 10.465"
-Tom
