0 members (), 100 guests, and 4 robots.
Topics128,261
Posts1,058,346
Members48,485
Apprentice
Apprentice
I decided to rebuild my 1955 235 cu engine that I have in my 53 Chev 1/2 ton. I purchased a cam and lifters combo, I wanted to go with the mechanical cam and lifters.Whats in it right now is hydraulic cam and lifters. Cam went in fine lifters AOK, but when I went to place in pushrods and rockers assembly it became obvious that the pushrods were to long. I looked up on Jim Carters site and saw that they sold shorter pushrods , they still seems a bit long. Has anyone else done this or came across this problem which can give some advice specifically somebody that has placed in a mechanical cam and lifters in a 235!
Sealed Power Part # RP3020 w/ Hydraulic Cam
Size - 11.474" O.A.L.
Sealed Power Part # RP3018 w/ Mechanical Cam
Size - 10.819" O.A.L.
Try your Local Parts Supplier
-Tom
1950 Chevy 3100 w/ 1956 235
Apprentice
Apprentice
Thanks’ OilRag
I thought that maybe somebody else might have had the same problem but the info you gave me it probably exactly what I need , like I said I think I need them a little bit smaller and from 10 9/16 to 10 7/16 is about the size difference I need . Thanks for the help... wave
There is a 10 7/16" push rod listed for the 216 engine
Part house #3019
Length 10.465"
-Tom
