| | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 35 | Hi All, I just picked up a dual carb Offenhauser for a Stovebolt 6. I'm trying to determine if it is a model 1034 (Early 216 and 235) or a model 1035 (later 235 and 261). The only casting letters are a small (3/16") A and a small R, both located just forward of the front carburetor. Can anyone help me identify which one this is, or any other clues to solve this mystery? Its either gonna go on my 1946 with a 216 or on a full pressure 235 rebuild that I am gathering parts for. Thanks in advance, Possum | | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | I think the only difference is the carb mounts. I believe the 216 vesrsion used the smaller throttle bore openings and the bolt mounting holes are closer than the 235 version? | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The ports are larger on the 235-261 version, but can be adapted with reducer rings. It is possible to run either on a 216-235-261 with the right ring reducers. The 1034 fits the 216. The 1035 fits the 235-261. This information straight out of the Offenhauser catalog.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | The easiest way to see which manifold you have is to measure the carb mounting bolts. The smaller setup is for the early 216/235.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Possum,
The bolt spacing for a 216 carburetor is 2 11/16". A manifold intended for a 235 will have a larger spacing...2 15/16". This is the center-to-center distance of the carburetor hold down bolts.
Stuart | | | | | Joined: Jun 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 35 | Thanks guys, The center to center on the carb bolts is 2 15/16, which makes it for the 235. Thanks again, Possum | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | i am still trying to find a member that talked about building his own dual intake anyone have any idea who that was lol can't even find his post anymore think he was from MO
1937 1/2 ton
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Daniel, Is this who you were thinking about? http://www.manifoldsbymoose.com/chevyregards, Leon
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | not sure but it will work  i had just seen a breif mention of him on some post
1937 1/2 ton
