1 members (Southerntruck),
148
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 15 New Guy | | New Guy Joined: May 2009 Posts: 15 | I am planning on doing a junkyard power steering upgrade. Any advice on gearbox, pitarm, and steering column? Is this even possible. I know about the kits, they just seem a little pricey. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | It's unlikely that you will find a "factory" power steering for a TF truck in a wrecking yard. It was an option but few were installed. You can obtain a Saginaw gear box from a 67-87 truck and purchase the adaptor kit from a variety of suppliers. Another option is a Toyota gear box from a 84-87 4X4. In each case you will need to do other mods, tie rods, pitman arm, drag link, column, shifter, mount brackets, etc. A column that is commonly used is from a 72 Chevy van/panel truck. You can use your existing key switch with this application. You can also modify your existing column and retain your existing shift arrangement. I have done several of the Toyota conversions and the only component that may be availabe in a wrecking yard would be the gear box. They are also scarce since the word is out about their use. Fred
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Buy a remanufactured gear box. Its not that pricey and you know what you got. I did buy a Kit from a vendor. The steering arm, and adjustable drag link, and a couple bushings/nuts and bolts were very good quality but at 100 bucks I thought still a little pricey. You can read a couple of good articles about converting your truck to power steering. There is one at this link below but I lost the link to the other one. http://www.classicperform.com/tech.htm | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | Also what engine are you using as you will need to mount the power steering pump on the engine. If you have a V8 you should be set as there are brackets out there, if its a inline 6 it a little bit harder as there isn't any brackets manufactured for the inline 6. I will talk more once I see what you have. | | |
