7 members (crenwelge, JW51, Lostbuthaulinass, Hugh63c10, Gray_Ghost, 1955 1 Series, greenie-reddy),
161
Mod | | | Forums66 Topics128,108 Posts1,056,237 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 18 Apprentice | | Apprentice Joined: Oct 2006 Posts: 18 | I'm looking for ideas on hidden fuel fillers for panels or burbs. Anybody have any pics or seen any good ideas?
Thanks, jared
'56 panel project
| | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | Hello Jared, For me the easiest place to 'hide' one is in the line near the gas tank. Make sure you have a shut off valve and then an electric fuel pump in front of it. All can palced inside the frame rails, this protects it as well. Hope this helps, Richard
Richard J Patrick - 1946 Suburban
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Patrick,
I am bad at visualizing. Where would be the "opening" for putting in fuel?
Tim
| | | | | Joined: Mar 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 46 | I think he thought you meant fuel filter. I've done a lot of body mods while playing with mini trucks I'll take a look at some pics of panels that body style and see what ideas I can come up with. | | | | | Joined: Oct 2006 Posts: 18 Apprentice | | Apprentice Joined: Oct 2006 Posts: 18 | Most likly I'm going to be putting an aftermarket tank in the rear between the rails. I may have to put sealed access door in the floor, with the filler just below that. Would rather not have to fill it that way. So I'm open for better ideas.
'56 panel project
| | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | Holy Stuff, My apologies, I did indeed read fuel FILTER not filler. Back to the eye glasses shop. Richard
| | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Could you maybe hinge a tail light and have the filler hidden behind it, like on '56 Chevy cars?...
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Oct 2006 Posts: 18 Apprentice | | Apprentice Joined: Oct 2006 Posts: 18 | Kind of thinking that, but the tails are small. I only have one tail that is in poor shape so I was thinking about another tail that could be a little larger like the 60-66 fleet side.
'56 panel project
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | I was thinking of dual tanks myself. I cut the fuel door and neck out of a wrecked suburban. Since you are dealing with a TF, you might want to take a look at that approach. Barring finding an original, you could look for a more modern vehicle for your fuel doors and get a matched pair. If you are using a new tank, you can cut and weld on it with no problem. I wouldn't put any heat on a used than, though.
Another thought is that any parts house that supplies over-the-road trucking will have both mechanical and electrical fuel tank selectors. The electric ones switch the gauge, too.
Best wishes,
Les | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Here's an example of the ingenuity involved in finding a solution. They are not specific to the Suburban, but they do open up the imagination. It may work if you decide to use a different larger tail light. Another way would be to dress up the original tail light with chrome trim/plate and hide the door behind it. 1955 CHEVROLET HIDDEN GAS CAP | | | | | Joined: Oct 2006 Posts: 18 Apprentice | | Apprentice Joined: Oct 2006 Posts: 18 | I like that. How do those mount, weld?
'56 panel project
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | mine is not exactly hidden but is installed flush with the fender with the tank in the rear. i go the filler from air ride technology but others sell it now. it does require a flanger to install and it is as much as the door. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
